We are getting real close to decking. It will be 4" thick with 3/8" rebar on 12" centers and I believe they will use cushion sand over the base.
Our ground is has lots of clay and they did soil injections into the bottom of the pool. So I have a couple of questions.
1) Should I do soil injections for the decking, just the large areas between the house and pool. I probably wouldn't worry about the walk path around the back of the pool.
2) Should I get larger rebar or is this sufficient? It sounds pretty good to me.
3) Should I request crushed stone as base versus sand? Will the sand need to compacted?
