- Mar 11, 2024
- 88
- Plaster
- Pentair Intellichlor IC-20
Hi everyone,
I am going into my first central texas winter with our pool and have a few questions regarding dealing with the occasional cold snaps that come our way.
Number one with the SWG. I am currently set to run 18 hours a day at 30% on our undersized pentair IC20. With the lower temps we’ve had recently I thought we’d be potentially needing to add LC but it seems that we are still overproducing since my FC was at 13 tonight. I guess I should further reduce my SWG percentage to reflect the lower demand? With all the leaves and junk blowing in constantly I am surprised it’s not needed?
Second question is with regards to runtime. Is it better to continue to keep the pump running when temperatures begin to flirt with freezing?
At what sustained temperature should I consider shutting off everything to prevent freeze damage? Or is it not likely to be an issue as long as the power is still on and the water is moving?
Thanks!
Thanks!
