New liner or new pool?New build just 3 mos
Is this the same pool?current construction of a 14 x 28 slope pool 3.5 to 6', vinyl liner, 3 steps formed in pool and an 18" full length bench at the deep end.
No, a new house with new pool completed 5/1/2024 16 x 36 with 42" metal walls vinyl liner; 3' shallow 6' deep; Hayward salt system with Coverstar auto cover.Is this the same pool?
Based on the dirt and corrosion, the pool looks a lot older than 3 months.
Is the corner square or round?
It is basically impossible to put a liner in a square 90 degree corner.
Corners should be rounded.
All liners should use liner lock.
Some installers use various items instead of liner lock like pennies or popsicle sticks.
The liner looks like it does not really fit correctly and the corners will probably be a problem.
The liner is already pulling out and it needs to be secured properly.
Ask the builder to fix it under warranty.
Can you show the pool before the liner was installed?
Here are some pic prior to liner install, I appreciate your feedback and wonder why coins would be used instead of the liner lock you’re referring to.It looks a lot older based on the dirt and corrosion.
In any case, it looks like they tried to make a liner fit into a 90 degree corner, which never works well.
It should be fixed as much as possible with liner lock to prevent the liner from coming out further.
The innovation of liner bead was a major improvement to the manufacturing and fit of vinyl liners, however the innovation highlighted the poor fit of liners in pools with square corners
Most likely the company ran out of liner lock and just used whatever they had available.wonder why coins would be used instead of the liner lock you’re referring to.
So, does this mean salt water is getting to my metal walls?Most likely the company ran out of liner lock and just used whatever they had available.
2 pennies are cheaper than a whole roll of liner loc.
I appreciate the information provided and you responding timely, my pool builder is supposed to come out tomorrow to hopefully fix these issues and some wrinkles.Most likely, some water will get behind the liner where it is out of the track due to splashing etc.
It probably won't be a lot of water overall.
Well it's pool water at 10% the salinity of the ocean, so you have that going for you. 120ft of liner lock is $27 on Amazon. Wrap the whole pool. It pushes right in with your thumbs and if there's any tight spots, use a rubber mallot and a piece of scrap lumber to give it some love taps.does this mean salt water is getting to my metal walls?
