Hey guys, I noticed that my filter pump was running low on inlet water the other day when it was making a lot of noise. So I cleaned all skimmers and filter baskets to no avail. At minimum pump speed the filter pump barely stays primed, and the downstream filter pressure is almost 0. The pool equipment is 15 feet below the water line and has never had this problem.
So I set about trying to figure out the issue. The skimmer return suction is very low, I can't even pull leaves off the bottom using my pole hand vac. My initial thought was that the skimmer line was blocked up, so I put a pipe snake 25 ft down the skimmer line and didn't get anything back. Then tried to alternate my CMP (I think) 3 way diverter return valve from skimmer to drain to try and get any obstruction to clear, no difference there but then this valve started to become very difficult to turn. It won't go past 3 or 9 o'clock into its normal operating location of 12. I think the valve is either busted or a kids toy is lodged inside.
Should I take apart the valve and see what's up? How do you recommend going about blocking skimmer and drain return (deep end inlet) lines? Tennis ball in skimmer and large tub with sand bag on drain? Just want to get advice before I mess anything up or go diving in 48 degree water...
