Hello TFP community. I've been lurking for a while and have finally decided to jump ship from my local pool store to TFP after much frustration. I have a 20k gallon vinyl inground pool with a SWG. When I removed my safety cover to open the pool two weeks ago, I had quite a bit of Algae on the bottom. I vacuumed to waste like any other year, added twice the amount of shock, and headed to the pool stool where I have had quite the run around getting my water balanced. Needless to say, its been two weeks, and my water is still cloudy and I'm seeing foam on the top of my pool especially in the morning. I can barley see the bottom of the liner in the 4ft section, however, cannot see the drain in the 5ft section.
I know this site doesn't trust pool store water tests, so I've ordered my Taylor kit, but wanted to see if anyone recommended that I take any action in the meantime. I got the numbers below from getting my water tested at two different pool stores (the numbers were very close in both stores).
PH 7.3
TA 86
CH 95
Salt 2900
FC 5.4
TC 5.5
CYA 39 - I added 3 lb of Stabilizer after this reading, and this seemed to make the foam situation worse.
Thanks in advance for your help.
PH 7.3
TA 86
CH 95
Salt 2900
FC 5.4
TC 5.5
