Hello! I am so glad to have found this amazing site! Prior to creating my account I found lots of great advice here when googling questions in a panic over the last two week, so thank you for that
I just bought a house in February in North East Ohio that came with an 18' circular above ground pool (3.5 feet deep as it's filled now, so about 6,600 gallons). I have NO prior pool experience and am currently struggling with cloudy water. I'm going to give a history of everything I've done to the pool to hopefully get the best insight to what may be causing my cloudy water:
About two weeks ago: Removed cover - the pool was half full will crystal clear water. A test strip showed it was perfectly balanced aside from lacking any FC whatsoever.
I proceeded to fill it up with the hose several days later. I know I should have retested at this point, but I was feeling overwhelmed with all the chemistry involved and just added 1 bag of shock. The water became cloudy.
It was too cold to swim over the next week, during which time I put a solar cover on it and only ran the pump at night to save on electricity. Then we had some storms, so one night I had to turn the pump off. Then the next day my son accidentally severed the power cord with the lawn mower and the pump remained off for 2 days until I was able to get the store to get a new cord.
When I plugged the new cord in I noticed the water had turned a deep blue-green beneath the solar cover. This time I knew I had to balance the water first...the test strip showed the PH was at the highest level the strips (HTH and Clorox) would register, and one brand of test strips (Clorox) said the alkalinity was also very high.
I added PH down until both the PH and alkalinity were in normal ranges.
Once the PH and alkalinity looked good I added some CA stabilizer until the level was within the target range on the test strips box (30 or 40 I think). Then I added 3 bags of shock.
The next morning the pool was still green. I added some HTH Super Algea Guard 4-in-1 Akyl algeacide and about an hour later the pool was blue with a milky white tint to it.
The water was still balanced and the chlorine level was registering the highest the test strip would allow. I continued to run the pump and a day later it was still cloudy so I added Clorox 3-in-1 Xtra Blue Clarifier. I chose this because it also claimed to remove phosphates (I noticed after getting it home that there is a total lack of ingredients listed on the bottle!).
2 days later it is still the same level of cloudiness. The chlorine was still very high this morning. This evening it was registering to be in the normal range and I added 13 oz of liquid bleach just to make sure the algea doesn't come back overnight.
I have a bottle of HTH Drop Out Flocculant as a next step but I'd like your opinions on what is going on before I add another chemical. I also don't yet have a vacuum and would link to know what the least expensive model is that will not be a piece of junk.
My questions are:
What could be causing the cloudy whiteness?
So far I've learned that too much CA means you must empty the pool and start over. What other chemicals should I be very careful not to over do it on? Any other situations where a screw up means you have to totally start over with new water?
And just out of curiosity: Why would one brand of test strips say the alkalinity was normal (HTH) and another say it was very high (Clorox)? I tested multiple times and the tests were both consistent in their difference of opinion.
Any idea what the ingredients in Clorox 3-in-1 Xtra blue are? I even called the phone number on the bottle (got a voice mail) and haven't gotten a call back in over 24 hours.
Thank you, everyone!
My questions are:
