I've read through so many forums and I "think" I'm on track but hoping a seasoned expert here can help me out. We have an summer waves elite 15x48 above ground with the standard filter/pump that came with. After last summer we drained all about half inch of water and of course over winter it got some algae growth. I skimmed nearly all out before we started adding water two days ago. Since opening, I have vacuumed three times a day, changed the filter once after the initial bulk of it was out, and I've hosed down the filter after each vaccum.
Chemical wise, I've used the HTC 3-n1 shocker on day one, day two I added half gallon of bleach, and today on day 3 8 added a gallon in the morning and a gallon this evening.
Unfortunately, I don't have the fancy test kit (I know I need one) until this Thursday. I have the three way drops and the test strips. According to both the test strips and the drops, my Chlorine and FC are high (which is intended since I'm trying to keep it high to kill of residual algae) but my stabilizer and alkalinity are low. Pictures of both are attached.
When I first went cloudy on morning two, I could see algae centered in the middle of the pool floor through the cloudy water. After much vacuuming, I can no longer see that. The water is cloudy but I can tell that big spot is no longer settling there.
My question is, since I don't have the fancy test kit, do I focus on keeping chlorine and FC high, and ph within normal limits (I'm currently 7.2)? Despite my CYA reading incredibly low on the test strips, my FC is still high- perhaps because it's 65 and cloudy here? Should I keep adding bleach daily and running filter 24/7?
