Cloudy water with consistently high chlorine ?
longinoa
Active member
Jun 22, 2024
44
Los Angeles, CA
Hey yall - I got a SWG installed late this last summer I am still trying to dial it in in the cooler LA weather. My FC readings have been > 19ppm for the past few weeks. I woke up this morning and noticed the pool was cloudy. It was not yesterday... I turned the SWG down last weekend and just assumed I went below FC and had the start of an algae bloom.
I just tested and got
FC 19
CC 0
PH ~8
CYA 60 (tested last week)
This tells me that my FC has likely been consistently high. I just dropped the percentage down to 20% as I want the FC a bit lower - but now I have no idea what is causing the cloudyness. Any thoughts?
Hmm filter PSI was a great hint... My psi was super low (like 0) - turns out my water level got a bit low, and my filter basket was full (n)
Great. Let's see if the filter gets the water clear.
If not, come back here and we will take the next steps.
TFP is a member supported 501(c)3 non-profit that is volunteer staffed and has no ads. Your support keeps the servers running so we can be here to help you. It would be helpful if you considered supporting TFP so we can be here to help in the future....
