- Jul 12, 2021
- 66
- Vinyl
- Pentair Intellichlor IC-40
Hello! We had a leak over the winter which has since been fixed. When it was first fixed, we opened, added chlorine, and just used the main drain and side filters for circulate the water and the water was clear (image attached). The wait to get the liner back in place and adding more water is what took longer than expected which turned the water green.
We’ve added two large jugs of chlorine because the water is too cold for our salt cell. The water cleared up but is very cloudy (image attached). I tested this morning via my Taylor kit (results in image).
I‘ve added the recommended 4lbs of Borax and will add conditioner later today (need to replenish). We will not add any additional chlorine to get levels down.
My questions - can the PH make the water cloudy? Any other thoughts? Does clarifier work? Help!
