new pool owners, new to SWG. Pool water is getting more and more cloudy every day. Can barely make out the main drain. Might be starting to get a slight green hue but it may also be our imagination. We added 3 bags of shock yesterday with no improvement. 3 days ago used clarifier with no improvement. every morning there is some visible dirt collected on the bottom in areas. when we use the manual vac connected to the skimmer, you can see dirty water coming out of the return. better results when we use the polaris 380. Do we have a water balance issue or could this be due to filter malfunction since dirty water is coming out the return lines, or both? what would cause the dirt to be going straight back into the pool?
FC 5
pH 7.8
CYA 70
TA 70
Salt 3300
CH 60
20x40 in ground concrete bottom/stainless steel sides; sand pump; circupool RJ series SWG; polaris 380
FC 5
pH 7.8
CYA 70
TA 70
Salt 3300
CH 60
