Cloudy water suddenly
Mdxfan
11
Syracuse, NY
Pentair Intellichlor IC-40
Thank you in advance for some guidance.
I followed TFP last year and everything went well. Pool has been open over a month now and I suddenly got cloudy water I can’t clear up.
11K gallon salt water pool with vinyl liner.
I turned up swg last night, I just turned it back down. Pump has been running almost 48 hours straight.
FC 5.0
CC 0.4
PH 7.4
TA 70
CH 80
CYA 55-60
Pool is 6’ deep, I can still see main drain covers, so it isn’t thick like milk, just cloudy.
Hopefully, I just need to give it more time.
PS I have the Taylor kit and I use the TFP app to track readings, suggest chemical adds.
Welcome to TFP
The SWG does not generate enough chlorine to kill an algae problem.
Have you done a Overnight Chlorine Loss Test to confirm you have an algae problem.
If you fail the OCLT then follow the SLAM Process
