- Feb 11, 2017
- 30
- Vinyl
- CircuPool RJ-45
I live in Georgia. I had a completely awful pool to start with this year. I did the slam and levels are all correct BUT the water is not clear. It is cloudy. During opening, I left the vacuum hose in the pool and it ended up draining about 1/2 of the water during the slam. I did end up having to start over with the new fill as it was still cloudy at half.
FC 14
CC maybe .5. barely turned pink so kind of unsure if it was even that much.
TA 70
CYA 70
PH 7.5
I have a 22,000 above ground pool. The SWG got turned on for a day and salt was added without me knowing with someone trying to help. I turned it off and only used liquid for the rest of the slam.
The pool looks like the CYA test and you can almost see the dot at the bottom before it disappears.
I need advice. I have never had this problem in all my years with any pool I have had.
FC 14
TA 70
CYA 70
PH 7.5
