sande005
- Aug 19, 2018
- 930
- Vinyl
- CircuPool RJ-45
Let's step back to this comment.Well it has seemed to work for the last two years and I’m struggling with the test kits
What are you having difficulty with? For now, let's just concentrate on getting you comfortable with testing for CYA and Free Chlorine.
Just to re-iterate, we have found repeatedly over many years and many pool stores that their testing is very suspect. In some instances, the manufacturers of their equipment note that the level of accuracy is far worse than compared to your Clear Choice kit. Some have inexperienced staff doing the procedure. The worst use it as solely a way to sell you their product.
In the photo of their test for CYA, they show a value of 50. The written note shows your test to be 35.
Your test in the kit is the same as we use in the States. You may have seen this, but here is Clear Choice's detailed "how to" instructions: How to test for Cyanuric Acid (CYA) levels – Clear Choice Labs
One other tip: As they note, having different amounts of light can change how well/how poorly you can see whether the image disappears. I find the easiest for me is to stand out in the full sun, but turn around so I am holding the tube in my shadow. Then the light levels are closer to the same from time to time. We recommend that if you are between lines, round up your answer to the next highest line. So if halfway between 30 and 40, call it 40 - not 35. That will give a bit of room for error, and not have any impact on what else you need to do using that result.
Your pool store will probably be testing indoors, which has VERY different lighting. Even if they have a fancy machine that uses its own light and senses the light level, it can then give different results than you get. Just like if you tested outside in the sun, and then did another indoors - due to the light, it would seem different. Hence why doing it under the same conditions each time is needed. Look at the chart above, the targets for 40 versus 50 overlap a bit. So your result of 40 is not much different from theirs. Who is more "right"? From decades of experience with 10's of thousands of pool owners here, we can be VERY confident to state that the odds are yours are more accurate. Despite the seeming variability that your own testing can have (especially when new at it).
Did Clear Choice include a sample of pool water to use? In some of their products they do. This has been pre-set to give a value of 50. You use that to check yourself on what it should look like when doing your sample. Contact them about getting one, if needed.
