Got a Clarity8 hot tub in August. Just under 500gal. I can't seem to go more than 2 months without having to change the water out due to inability to clear cloudy water. I have had a pool for years and religiously follow all the TFP advice and have had great success with my pool.
I first started out only using the Dichlor that came with my tub. I inevitably skyrocketed my CYA because I stupidly wasn't watching it. Doh! You know what happened next. - drain and fill.
The next fill, I used a little Dicholr the first couple weeks to get CYA up to like 30, then used 12.5% "pool shock" moving forward. I ended up eventually getting lazy and let the water go too long without checking it. Water went cloudy and it was taking too long for my patience to clear, so I did a dump of the water again.
I then decided to tryout the Frog. Things have been going mostly great for 2 months. For the past couple weeks, I've noticed extra cloudiness in the water when the jets are on high (aerators are closed). On Friday, I noticed the water went completely cloudy and my grey cartridge was completely empty. My laziness yet again got the better of me as I was expected more time out of the cartridge. First one was used up in almost 4 weeks, and this one was just knocking on the door of 3weeks. I definitely used the tub more recently which would add to the faster utilization. But now that my water is full on cloudy it's taking forever to clear it. I shocked it multiple times using MPS and added 1tbsp Dicholr as a "startup" for the Frog with a new grey cartridge. Yes, I'm watching my pH and TA as well. It's progressing, but REALLY REALLY slow.
I added 1oz of Dicholr today, did a shot of 2oz 12.5% bleach, and just did another. Tub seems to be eating through the bleach pretty fast as I am checking my FC levels around 20min after adding and I haven't seen the level rise about 1 yet. (using the TFT droppers). So I figured I'd keep doing that until I see things stabilize and/or the water clears?
Thoughts? Or should I just drain/fill when the weather cooperates. I'm in Massachusetts.
