foosboy2 said:Okay wife checked at 8:30 and measured 6.5 FC and added another half gallon of liquid chlorine.
I got home about 10:30 and measured the following:
11.5 FC
2.5 CC
210 TA
390 CH
25 CYA
7.5 PH
Going to check the pool calculator now but looking for comments before adding.
Update Pool Calculator only told me to add a little chlorine. It also said stabilizer but I think we want to hold on that. Comments?
Mitch
Michigan
8000 gal, IG, Fiberglass, Jandy CS 200 Cartridge Filter, new filter August 2011
Free chlorine 11.5 ppm
Total chlorine 14.0 ppm
Combined chlorine 2.5 ppm
pH 7.5
Hardness 390 ppm
Alkalinity 210 ppm
Cyanuric acid 25 ppm
Measured 5/21/12 @ 10:45 PM
Fabulous! Great to see that FC number! Still got some CC's. That was expected. Either you did add some muratic acid to lower PH or the test is inaccurate at high FC. Did you add some? Save your CYA test now for if & when you want to bump it up a bit. But don't do it till the shock process is over. You'd just have to add more chlorine. If it were my pool, I'd add enough chlorine to get to 14 or so & see how it drops in the AM. It will surely drop some & I'd bump it up again just abit higher than the 12, (the sun depletes chlorine also). You've got to be excited!
