Help!!!!My pool is cloudy. I have shocked a couple of times. we have ordered the Taylor K2006 test kit and it should be here Wednesday. I have tested the water but only with a Salt Scapes test strip. Below are the results although I know they are not the most accurate.
total hardness - OK high 250
TC - OK 1
FC - 0
Ph - OK 7.2
TA - OK 120
CYA - very Low
We have a salt generator. The pool has been shocked twice and algaecide was added because there are some spots of black algae. We run our pump 24/7. When you go to pool places they all tell you something different. The past two winters here have been abnormally warm which has caused more algae than in the past. Please help!!!!!
TC - OK 1
FC - 0
Ph - OK 7.2
TA - OK 120
CYA - very Low
