- Jun 24, 2021
- 16,046
- Vinyl
- CircuPool RJ-60 Plus
Tomorrow ill get another, but there is no change so far.
Never hurts to get a second opinion.but there is no change so far.
Yes seeing the dead algae, and yes to adding DE.Are you seeing dirt accumulate on the steps, or getting clouds when you brush areas the robot doesn't get to well? If so, you are killing algae and therefore making progress. Are you still adding DE?
It didn't go too far.I think its in the pool.
24 to 48 hours with DE if not more. I backwashed last night because we had tons of rain, and then added DE but still not catching much.How quick does the filter need cleaning when using DE ? Are you getting hours or minutes ?
I would try adding a little more DE. When it works it's usually much quicker.24 to 48 hours with DE if not more.
Then I would go with trying a little more DE at a time until the cycles shorten considerably. 24 to 48 hours doesn't seem to be trapping enough crud for how efficient it usually is when adding DE.The sand was all new last year and I added to it the day before starting this thread.
X2! Even the shorter cycle time noted in an early post was a bit long. So the DE is doing something, just not enough.Then I would go with trying a little more DE at a time until the cycles shorten considerably. 24 to 48 hours doesn't seem to be trapping enough crud for how efficient it usually is when adding DE.
It has nothing to do with "turnover time" and the filter is plenty good. Get more DE in there where it'll up the gauge "1" psi and you won't go close to 24 hours before the pressure is up. Actually make yourself available sooner then later for the backwash.I looked at the Hayward filters, and while their 300lb one might be a bit on the small side for your pool, it's not by much. Especially with the lower flow from the 3/4 hp pump. Just means the total turnover time is longer. Which means clearing will take longer. Going up in DE should help the situation a lot.
