That was my pool all summer 3-4 months. Backwashed once a month maybe, as pressure was always the same.
Did you at all add DE during this time? If you add DE now, does your pressure rise this quickly in a day or so, or at least 2-3 days? If so, then clearly I am thinking that your sand has been compromised through magic potions, like clarifiers, etc.
First year with a pool, so no clue if my filter is acting normally or not. Tearing it apart and cleaning it may be more than what I'm comfortable with.
If you are seeing fast rise with DE in a few days after the SLAM, then the sand change (in this case may be your best bet). We usually do not recommend a sand change unless absolutely necessary. If you are not comfortable with the deep cleaning first, then hire someone for the project, etc.
Personally, I have not cleaned my sand since day one. During the season I use skimmer socks, clean the floor with socks, etc. Very little if any debris will get past the skimmers and the pump basket. Considering my filtering is at par, especially with DE Fiber Clear, I feel that taking it apart may be worse. Why fix something that is not broken. As mentioned earlier, I started the DE this year because my filter pressure never increased as my sand filter pressure never increased. There really is no junk that enters the pool and now that a big oak tree is coming down, there will be almost nothing at all.
Good luck and keep us posted. If your water is crystal clear without the DE, then nothing to be done. But you are telling me that your floor is still not up to par. Try also using skimmer socks when vacuuming as everything on the floor and walls will be caught in the sock. Take your time as the hour you spend vacuuming super slowly will ensure that you do not loosen anything up. Thanks!
