I've got an above ground pool that has been cloudy for a week now with no progress getting more clear.
Test results are:
FC & TC : 15+ppm (I didnt want to waste reagent to test any higher)
PH : 7.5
Alk : 110
CH : 300
CYA : 40-50 (in middle)
The chlorine has been 15+ ppm for the last 3 days. No new chlorine has been added since. I could do an overnight chlorine test, but at these levels, is it really necessary? That's a lot of reagent to use to get the actual chlorine figure.
Can the pool be cloudy from too much chlorine? Or should I assume it is a filtration issue? I can not see the bottom of the pool and it's about 4ft deep.
Any help is appreciated. Thanks
Test results are:
PH : 7.5
Alk : 110
CH : 300
