- Jul 14, 2023
- 11
- Fiberglass
- Pentair Intellichlor IC-40
Hi forum,
This is the first season we are closing our fiberglass pool with embedded hot tub. Despite my wishes, I have agreed to allow a "professional" close our pool to be a good spouse. However, I've been thinking about our pool, the hot tub, and winterization because I want to ensure we don't have any unexpected issues come next year.
I think our pool will follow a relatively standard winterization process with the exception of the hot tub suction lines. Since they are only ~2' feet below the water surface, I believe we'll need to request from the company doing the closing that the lines are plugged and filled with antifreeze. A simple airlock will not do. I've attached a picture for reference.
Are there any other precautions I should look out for?
Within the pool there is one skimmer, two drains on a single suction line, and three return jets (one return line). In the hot tub, there are two drains (1 suction line) and 6 return jets (two return lines, 1 from pool equipment for spill-over, 1 from hot tub heater).
I have confirmed with the closing company that they will not drain any water as that would void our pool warranty.
