Hi Everyone,
Since this was my first year closing the pool I didn't want to do anything wrong. I hired a company to come out and close the pool. Before closing the pool I checked my levels (FC 12, PH 7.8, TA 90, CH 177). I cleaned the pool, scrubbed and vacuum and set the robot on it all day. I then backwashed it 2x thoroughly and took out the ladder.
He came over and just had a couple of questions.
1) He added no chemical should he have and should I?
2) There was no drain plug in the heater and he did nothing inside the heater, should we do something? I remember a switch inside the heater. He did turn off the gas line
3) We added those air balloons I had but we did not tie it off so it is just moving around, should I go out and tie it off??
4) He tied it down over the skimmer, is this correct and does will this add pressure?
5) I have an inline salt gen should he have done anything?
He Complete
1) Used a crazy pump to drain the water 2" below the return jet
2) Put a plug in the return
3) Put a plug in the skimmer that I bought. Swimline Skim Guard Winterizer Gizzmo (Black) | Pool Supplies Canada
4) He unplugged everything and turned the gas line off
5) Blew every line and every component separately with an industrial blower and until it came out clean beyond the mist.
Anything else I should do? I think he did a decent job besides the balloon.
Thanks Terry
He Complete
Thanks Terry
