Hi everyone! I'm in Canada and I'm closing my pool by myself this year. I've watched some videos but it seems like a lot of pools are different and hoping to get some advice for mine and clear up some confusion regarding blowing out lines and make sure I dont cause any damage.
Firstly, I have 1 skimmer with 2 holes (see pic below). I was told the one closest to the pool is connected to the main drain and the other one connects to the pump.
Secondly, there are 2 pipes that are underground that connect to my system (see pic below). 1 connects directly into the pump and the other appears to connect to my chlorinator, which I assume goes out to the jets.
Thirdly, I don't believe there are any valves that control water flow besides the pump's settings (circulate, waste, backwash, etc). There are those 3 valves but I wont be touching the 2 that are for the solar panel. The third one at the bottom looks like it blocks off the pump inlet. Not sure if I need to do anything with that?
Question 1) It seems like a simple system, but Im not sure how the main drain works. How does water flow? Does it even connect to the pump or just connects to that first hole in the skimmer and then goes to the pump?
Question 2) With this simple system, do I even need to blow out the lines with a vacuum? Or can I just lower the water below the skimmer then turn the pump to circulate (or filter?), remove the filter and pump plugs, and let the air evacuate the lines and just use Styrofoam rope and anti freeze in in both holes before plugging them? As well as antifreeze with a funnel into the return jets before capping them too?
If I do have to blow out lines, can you tell me how exactly? I have a shop vac.
Thank you so very much for taking the time to help me,
Tom
Tom
