Hi guys after reading all the threads in this post I must admit I almost there getting the Cyclone. A few more questions that will help me and hopefully others as well.I have 3 valves on my system see pictures. Do you drain all water from pumps, Filter and Heater before you start the blowout process? You can see in the second picture, first pump from the suction side comes from the main valve and the shallow skimmer ( I verified by turning pumps off and checking suction) the same pump returns the water through the filter then to the heater and then out to the valve at the bottom of the 1st picture or the 4th picture going to the Return and the Fixed Nozzle. (the fixed nozzle is part of the
Paramount PCC200 floor system)
The second Pump (3rd picture) sucks from the Suction Cleaner? and pushes out to the floor system which I think goes directly to the
Paramount valve as well as the deep end skimmer.
As far as the floor system I feel that is very simple since I do have the correct Schrader valve plugs for the Paramount valve.
I have the gizmos for the skimmers and plugs for the returns.
What is the best way of blowing out this system.
I also want to remove the pumps and bring indoors for the winter. Do I get plugs for the connections at the unions?
I am hoping to get a new company in here by the end of October and will be sure to watch them carefully for the procedure. i am trying to learn this in case I cant get them out here before freeze.
I would also like to thank everyone for their input on these subjects and big shout out to Catanzaro who has written some great articles on all pool subjects.
P.S. Do you think the Cyclone would blowout an irrigation system (maybe able to convince myself to buy for that reason as well)
Side notes, Pool closings up here in MA $375.00 last year
