I am considering leaving the pool up this year over winter. I have read a number of threads and got a grasp of the situation from a chemistry point of view but some questions remain re freezing.
I plan to drain the pool to below the lowest inlet/outlet. At each inlet and outlet I have shut off valves installed, should I remove the shut off valves from the pool or is leaving them "open" with the water drained below them sufficient? Here in the UK, some days of below freezing temperature are likely. Removing them would mean exposing an open hole I cut when installing them.
I have a hayward skimmer installed and im assuming I can leave that in place as long as the water is drained below it?
Thanks.
Thanks.
