Hey guys, here's the deal I'm in NC. Daytime high just above freezing night time lower teens.Last night we lost power so the pump stopped and pool iced up. Power came back on 8 hours later while I was at work. So once I get home and as I was trying to break the top layer of ice up in the process ripped a hole in the linear. Normally I run the pump 24 hrs a day until the weather passes however with the leak/tear it was losing water below the skimmer. I now need to get rid of the water below the jets. Normally I don't winterize but now it seems I have no choice. I'm lowering the water below the jets and am going to plug the 2 jets, skimmer and turn off the pump. FYI the liner is like 15 years old and was planning on replacing anyways. Question is what to do now so my equipment doesn't freeze up and the pipes don,t crack.
Thanks TTP guru's in advance.....
