We did a soft closing several weeks ago by putting our mesh cover over our pool to keep leaves out and running the pump with the cover on instead of closing early to deal with the leaves like we usually do. Water temperature has finally dropped below 60 degrees so we are going to get it closed by a pool service in a few days. I bought some polyquat to add at closing because I’ve discovered that our old mesh cover lets in too much sunlight and we tend to get a lot of leaves in our pool, which decreases FC. After testing the water, I’m not sure if I should use the polyquat now because FC isn’t down to half SLAM yet, even though we haven’t added chlorine in over a week and we had several hot days last week. Here are my latest test results:
FC 14, CC .5, CYA 40, TA 70, PH 7.8
Based on these test results and the existence of an old mesh cover that lets in rainwater, some sunlight and leaves, what would be my best course of action before before closing?
* Could I go ahead and add the polyquat even though FC isn’t at half SLAM or below yet?
* If a chlorine level that high could decrease the effectiveness of the polyquat, should I reduce the chlorine with a chlorine neutralizer so I can use the polyquat?
* Or would I be better off closing at SLAM level and adding chlorine over the winter while draining water out with my sump pump? If that is my best solution, I need to know if there is a way to get an accurate chlorine reading so I’m not getting FC up too high since high FC can damage the gelcoat.
* Are there any hacks for keeping leaves from blowing under the cover over the fall and winter? I don’t have a robot to throw into the pool to get leaves out and removing the cover to get them out with a net attached to a pool pole would be difficult.
* Would it help if I added a tarp to my mesh cover in late winter once the threat of snow has passed? Someone on another thread suggested adding a tarp but I worry that a tarp could damage my older mesh cover since it isn’t in the best shape if it remains on the pool during snow season.
