I have some questions about closing an inground fiberglass pool.
1. How much do you need to lower the water when closing it if you have a mesh cover and you plan on blowing out the lines, put in winterizing plugs, and a gizmo in the skimmer? Do you have to lower it below the returns since rainwater will be able to get into the pool over the winter or can it just be lowered below the skimmer?
2. Since my calcium level is only at 100, should I increase it before closing? I've read that low calcium levels can harm the gelcoat, cause damage to the waterline tile, and cause staining so I was wondering if I should try to increase the calcium level before we close. If I need to increase the calcium level before closing, how high of a calcium level do I need to strive for?
3. On the day of closing, how high should the FC, PH, TA, CYA, and CH be? Should I use Poly-Quat if I close before the water temperature drops below 60?
