I would like to Thank Everyone in this group for your help, your advice and your knowledge. It is a pleasure to belong to this group.
I have what I suspect is a copper stain issue. The copper and CYA levels are both very high and I’m getting stains on the plaster. I suspect my own negligence is the cause and now I’m trying to fix it.
I purchased a gas heater and a chlorinator three years ago. A local pool service company installed them both and the chlorinator is downstream of the heater. They didn’t install a bypass valve from the heater and I didn’t know to ask for one. Now I have copper problems which I assume are caused by the cholinator. I have also learned that chlorine tabs cause high stabilizer issues over time.
Assuming I get rid of the chlorinator and fix the water with water changes, and stains, will the heater be OK to use going forward? Or, will it forever leach copper in high amounts?
