Clogged Test Chemicals
johig
50
Mission Viejo, Orange County, CA
Pentair Intellichlor IC-40
Hi All. The dropper/bottle for one of my test chemicals (R-0011L from a TF-100 kit) is clogged to the point of being unusable. Anyone have any tips for unclogging it? At $6 it's not a huge deal but I figured it was worth asking in case I'm missing an easy fix. Thanks!
revitup
432
Pawleys Island, SC
Fiberglass
Hayward Aqua Rite (T-15)
Pop the tips off and clean it in hot water. Never probe it with anything as that will change the droplet size.
Are you sure the droplet size isn’t controlled by the shape of the tip?
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,518
revitup is right. It is the way in which the chemistry "falls" from the tip that determines the drop size.
That said, I have never hear of the chemistry becoming clogged. I have also never heard of the chemistry being clogged causing an innaccurate drop. Does it show up in a pic?
johig
50
Thank you both. I knew about not probing it but was not sure if, and how easily, the tip came off. I was reluctant to force it given the container is still quite full and I didn't want to get R-0011L everywhere. Turns out it popped off nice and easily, thanks for the guidance!
