Ive got everything I need to clean the cell but can't figure out how to get the water out of the cell before I take it off I turned the pump off and nothing...I feel like I'm missing something THANKS!
you can unscrew it, it will be fine.. it means you have no leaks.. you can also unscrew the bottom of your filter or take the lid of your pump to lose suction and let the water return to the pool
How do you know it needs cleaning? you only want to clean them if they really need it... it is not something that is just done because or at a certain time schedule...
Every time you acid clean a SWG cell you remove some of the rare earths from the plates and reduce its lifespan. Only do it when you see scale on the plate that cannot be removed with blasts of water or a stick.
Well I just went back out and turned the SWG back on and everything things fine....Only the Generate light is on now. My pump runs pretty low throughout the day does there need to be a certain number of gallons per min for the SWG to run properly?
Ok so now I see it could be inadequate water flow that can cause the cell maintenance light to come on. Ill look in the manual to see if I can find the proper flow and set my pump to it
