Hi folks. I've been following the TFP method for the last 11 years since my pool was built. I have the TF-100 test kit and familiar with the different chemical levels. This message is concerning my brother's swamp of a pool. When he was having pool issues a few years ago, I suggested that he stop using tablets and drain part of the pool to get the CYA in check and it was clean for a little while, but is green again. I don't believe the pump has been on for a while. Unfortunately, my brother passed away a few months ago and I offered to clean the pool for my sister-in-law. I went over yesterday to run some tests. I didn't run through the whole gamut, but came away with the following:
CH: 0
CYA: 0
pH: 8.5+
TA: 70
I was expecting the CYA to be through the roof, but after mixing, the sample was not the least bit cloudy. I also found 4 gallons of liquid chlorine in the garage, so evidently, he drained the pool and switched to liquid chlorine, but maybe didn't add any stabilizer. The chlorine was probably burning off so fast, he couldn't keep up with it. In preparation, I have a few questions. I'm going to add CYA to get to about 30; probably use the liquid conditioner for the speed. Also will add acid to get the pH down. The basic pool stats are: 20,000 gal, in-ground, concrete, spa, Jacuzzi VS pump, Hayward DE filter and multivalve, heater, built in approx 1980.
1. First step is to scoop out as much debris as possible. I've never used a pool vacuum. Should I plan on buying one for the small debris and dead algae and vacuuming to waste, or can I get by with just brushing and let the filter catch it all? If I do vacuum, I was going to try to use a skimmer plate so the basket will catch some of the larger debris.
2. This will be my first experience with a DE filter (I have a cartridge on my pool), but I've read a few tutorials on how the multivalve operates and how to backwash. Is all DE material the same or are there different types?
3. Since the pump needs to be on 24/7 while the algae is being killed, does it have to be at full speed or can I dial it back to half speed?
4. This system is way more complicated than I'm used to. I don't have any valves on my pool, but this has a bunch. With a single pump, is the flow diverted to either the spa OR the pool; does it ever go to both? I want to post pics to see if some of the TFP members can clarify what some of the valves are for; should I post in this thread or create a new thread in the pump forum?
Thanks for any feedback.
CH: 0
CYA: 0
pH: 8.5+
TA: 70
