- Nov 12, 2017
- 11,909
- Plaster
- Pentair Intellichlor IC-40
No salt build up should happen. There should only be minimal salt residue left in the resin. If you are getting salt it’s because you’re filling while it is regenerating and the bypass is not working right.
Sodium replaces calcium. The counter anion (negative ion) does not change.
Thanks, J.
Because I cannot control when the regeneration happens in relationship to when the auto-fill fills (because a hot day might require the auto fill to run all night, right through the regen process), I was figuring that the softener's bypass mode would allow hard water to enter the pool from time to time. That's going to happen. It'll still be better than not filling with soft water at all. I guess I'm just curious about what a softener will add in place of the minerals it filters, and what I might need to be looking out for.
But so far, I can't find a single online reference that states topping off with softwater is a bad idea...
And unless I find out otherwise: I'll just monitor salt and CH levels until one or the other is too high, then start over...
There's another wrench in the works though, I also have a whole house filter, right before the softener. So the auto fill's supply is both soft and filtered. I haven't yet tested all three for comparison: pool water, street water and filtered/soft water, to see what's really going (or not going) into my pool. I'll get to that and report back. But again, this is somewhat academic: I just test and add or replace as needed... assuming, that is, that I need not test for anything that is not covered by my K2006 and the companion Taylor salt kit.
Considering my old water was likely never tested for anything but chlorine and pH for its entire life of six years, I'm still light years ahead of what's been going on BT (Before TFP)!
