Cleaner line conversion to a regular return?
Neto
318
Puerto Rico
So my pool builder is adding a cleaner line to my pool, its standard practice for them. This is basically just an independent line that runs from the equipments to the pool and you can move a valve to control the pressure, there is a pressure gauge there too. Since I am planing to buy a robotic cleaner, wan this line be used just as a regular return?
thanks
My builder does the same thing, except that when I deleted the booster pump and pressure cleaner, I had them connect the line to the suction side of the pump (with its own valve). I use is for vacuum cleaning during times of heavy leaf drop when the robot has a hard time keeping up.
Reactions: Hootz
