- Jun 13, 2021
- 46
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
On this page, which was last edited in June, can you please add some guidance on overnight filter operation? It isn't clearly stated here, yet it is implied if you are SLAMming because that process expects continuous operation. If I am only using the OCLT to detect if there is a problem in the first place ... I'm not sure what mode the filter should be in.
Also, in case it is missing, indicate that SWG should be turned off overnight if filter is operational.
www.troublefreepool.com
Perform the Overnight FC Loss Test (OCLT)
The Overnight Chlorine Loss Test tells if the SLAM is finished or if you need to start a SLAM. This article says how to do the OCLT.
