Clarification of steps.
Wilson3107
8
Americus, KS
Pool opened today. I can see the bottom, but there was a hole in the cover, so there is a nice layer of green dust on the bottom.
Ph less than 7.
CYA 0
FC 0
Temp 60.
So, first.....raise the pH to at least 7.2.
Then add CYA.
What confuses me is the "no backwashing for a week".
What if the pressure goes up? Can I backwash or not?
So, I added soda to increase the pH. Should I add stabilizer to increase the CYA? Then SLAM next weekend?
I bought tons of liquid chlorine today, but it's the first time I've opened a green pool and my COVID fried Nurse brain can't remember the proper steps.
Thank you all!
Texas Splash
That's not true unless you add stabilizer directly to the skimmer which goes to the filter undissolved. That's why we recommend the sock-soaking method. Once it's all dissolved, it's in. Good-to-go. Then you can backwash whenever you need to.
SLAM next weekend? Are you saying you have to work or can't start until then?
Wilson3107
8
Americus, KS
No, I was misunderstanding the "no backwash".
I always do the sock method.
So, once my ph is up to at least 7.2, I can add the sock, and start my SLAM?
I'll have the rest of today, all day tomorrow, then I go back to work, so it will be mornings/evenings.
Casey
11,515
SW PA
I would let the pump run for a half hour to circulate the water and then retest everything n go from there. Adjust pH if you need to and add CYA and start the SLAM.
