I received an email concerning a new product that CircuPool has come up with: its TotalBalance CO2 pH Control (Acid Free).
I assume that I received this information/brochure because I have an RJ-60 SWCG...and must've given them my email when I registered it.
The product purports to work by injecting CO2 into the pool water via the drain ports of your pump...coupled with an electric control box that monitors/titrates the amount of CO2 that is necessary. It does require obtaining a CO2 tank (or two, or three, connected together), which needs refilling quarterly to seasonally depending on conditions with your pool and water.
It just struck me as a curious product to automatically control pH, although it seems expensive and involves getting CO2 canister refills that might be a hassle, particularly as an occasional splash of muriatic acid keeps my pH reasonably in check.
I searched the site and found a bit of discussion about using CO2 to control pH in this thread: Co2 for PH control
But I was interested in what others thought about CircuPool's product and its "patented process" of CO2 infusion method of controlling pH?
www.circupool.com
CircuPool TOTALBalance pH Control (Acid-Free)-TBPH
