- Feb 2, 2021
- 216
- Plaster
- CircuPool RJ-45
I have a 13,500 gallon plaster pool with a Pentair VSP, 60cu DE and no heater or spa.
The SJ 35 is on sale right now for $749.. is this a good unit? I talked to discount salt today and he told me with a VSP to just run it very low RPM for the hours you don’t want to generate chlorine then boost up the rpm enough to trigger the flow switch ( will take some tinkering) for the hours you do. This will eliminate having to add a timer and will make the unit last longer he says.
