Circupool RJ60+ report
DAB942
426
Space Coast, FL
Instead of tacking on the old thread -- made a new one. I finally everything up and running. Had it on Super for 24hrs. Tested yesterday -- FC was at 13. Turned it down to 50%. Today it was at 19. Turned down to 35%. Hoping to fine tune and get it locked in. Still dissolving CYA. I'm hoping mine wasn't in the bad batch.
DAB942
426
Space Coast, FL
All is not right with the world. FC is reducing every day. I set it to Super Cl. Since it was 19, it has decreased every day. I don't know if something is wrong with the unit or not. I shouldn't have algae as the overnight test is less than 1ppm.
Mdragger88
1,281
Hernando, Ms
That’s def too low for Florida- it needs to be 70 or so at least.
Lots of rain I suppose- did u do the sock method/ granular?
if u put it directly in the filter it may still be there.
laprjns
448
Ellington, CT
You still haven't done the test that was describe in the old thread to determine if your RJ-60 is producing at the specified rate ( 3.1 Ibs per day). In your pool, running at 100% for 24hrs the RJ-60 should be producing 15 ppm FC per day. At that rate, it doesn't matter if your CYA is at 40 or 70, FC shouldn't be decreasing. You either have algae or your SWCG is not producing anywhere near it advertised rate.
