Bought a brand new RJ60+ swg. It ran fine the first week, then powered off. I had verified the voltage via my intermatic timer label and voltimeter. The jumper was configured correctly in original stock location. Put it back and it ran fine. A week later, it powered off again. Took the backing off again to check the fuse. All is fine. Checked that the wiring was securely in, it was. Only thing I noticed odd was the reset button was loose and didn't feel like there was a spring to give it tension (not sure if it is supposed to).
It powered on for a few seconds, then faded off.
Has anyone else experienced this? Frustrating since it is new and this isn't my first issue with the unit I got. Never received O- Ring (still leaky after installed), flow meter coupling was wrong size(they knew they were shipping out some models with the wrong size - not sure why they wouldn't open to check before sending) and flow meter piece was broken.
If anyone has experienced this, would appreciate insight on how it was fixed.
Unfortunately, DSP has a very small window for hours of operation.
TIA
TIA
