- Aug 27, 2017
- 97
- Vinyl
- CircuPool RJ-60 Plus
I have one on order but while I am thinking through things, I want to make sure I am correctly accounting for how things currently run.
I have an electronic timer that sits between the electrical panel and all of the pool equipment. Basically, it allows my system to run every 30 minutes for 30 minutes or so (I think it is set to around 10 hours of runtime a day). So all of the equipment is switched on. Power is cut and once restored it all comes back to life, etc. My current SWG (that died) has a toggle on/off switch. Looking at the RJ60 it appears to be a button...
Question #1: If the RJ60 is on and running, and then say the power is cut (timer in this case), maybe a power outage in others, will it turn back on itself?
My piping area is small. It appears I might need to install it vertically.
Question #2: If I install it vertically, can it come right after a down 90? If not is there a minimum distance needed from the elbow to the cell? I will have to install the flow switch after the cell, but according to the manual, this should be fine.
