I recently purchased the RJ45+ package in May 2020 and just installed it in Late June. Since installing it, it has had an error of Cell Connection. I contacted CircuPool directly about this problem and they sent me an adaptor to install that "should" fix the problem. Got it installed and still said the same thing on the display "Cell Connection". I called them a second time to discuss the issue and they decided to ship me a NEW cell as a replacement. Got it last week and still didn't fix the problem. Called them back a third time and they sent a return label for the controller and the replacement cell. This problem occurs when plugging the unit in to Power it up. It shows "Cell Connection" whether the Cell is plugged in or disconnected. Also, The Power light is on but you cannot turn the unit off or scroll through any of the menu options. It just stays on and you have to unplug to Power it down. I received an email yesterday (July 22) and here's what they said. See below for their replay. Here are the things I've checked per installing and trying to troubleshoot.
Switched wiring to 110V
Made sure unit was completely dry per installing
Checked connection pins on the bottom of the control box to make sure they weren't pushed up
Double and triple checked direction of the Flow Switch and Cell
Has anyone had this issue and what did you end up doing to solve?
Email received
Order Notes |
Your equipment passed all tests and all readings were accurate. The equipment is 100% operational and NO parts have been found to need replacement. We could not recreate a cell connection issue. |
