- Jul 25, 2014
- 10
- Plaster
- Liquid Chlorine
- CircuPool Edge-40
So, I finally decided it was time to convert my pool with a SWG. I purchased the Edge 40 from Circupool. My issue is how to best install it. I have 14” of straight pipe going down in the return, but it’s very short coming out of the filter output. I’m considering installing the cell on the 14” vertical and replumbing up or out from the filter output and back to give enough straight run for the flow sensor. Alternatively, I could try to run vertically up right after the filter output or horizontally out and back. This way I would install the cell and flow sensor on the added plumbing and leave the 14” existing vertical alone. Wanted to see if any of you who are much more knowledgeable than me had any advice on what you think would be best? Photo of my equipment included for visual.
