I am planning on going SWG and changing to a CircuPool, Black & Decker or Calimar VSP.
I am aware that normally these pumps are intended to run all day or run most of the day then turn off and start the run sequence again the next day. Generally this would work for me but I would like more control and make it easier to adjust to the seasonal changes.
The for those that worked with this Interface Kit am I understanding that the the speed is programed at the pump and the on/off time for each speed is controlled by closing and opening an external relay across three terminals that correlate to 3 of the programmed speeds?
Does the external relay need to remain closed for the pump to run or is the runtime as programmed in the pump like the speed?
If more than one relay is close what speed will the pump run at?
When Remote Control Scheme 2 is used, does this just allow remote control of when the pump's programmed run time and speed sequence starts? or does this work differently?
Automation Interface Kit Manual
