Hey all, just wanted to ask if I should be concerned about the chronically high pH in my pool. See my signature for all relevant info.
My numbers seem ok but I have to add a lot of muriatic acid (about 1.5-2 pints every two days). I have a big waterfall feature and a couple bubblers but I don't run them very much (just enough to keep putting fresh water through them. My waterfall is losing water and so until that is fixed I only run it about 30 minutes a day). So I don't think aeration is a factor. Now, the plaster was just done on Oct 1st of last year, so the plaster is only 8 months old and I know that the curing process can last a long time but should I see pH rise in as little as day back up to ~8 or so when I have adjusted it down to about 7.6? Should I consider doing anything more to stabilize the pH or just accept that it might be a long while until the plaster stops affecting it?
