Can you post some pics of it?
When it get's on the walls is it typically in the shady areas, or other places too?
If your FC was 2 ppm and if the CYA was 52 ppm then there's no wonder you've been getting algae. However, these numbers are probably wrong anyway since pool store testing is notoriously inaccurate. If you were using stabilized chlorine (Trichlor, Dichlor) then the CYA number may be higher than they report. You'll know much more when you get your test kit so be sure to post numbers when you get it.mom of 5 kids said:This happens while the chlorine level is maintained at 2.
