- Apr 24, 2021
- 43
- Vinyl
- CircuPool RJ-60 Plus
Hello! We were off to a great start thanks to this forum, but then the pool got mostly ignored during a family thing. There are many layers of "not-ideal" happening with the pool. Can you all see my pool math logs?
1. When i do the chlorine drop test i get 6 free chlorine .5 combined chlorine, (so 6.5 total). When i do the chlorine test with the daily box tester i get nothing, which should be true since we've added no chlorine.
2. Back-story: We had started the effort to get the CYA numbers up weeks ago but the granules from the big canister will NOT dissolve with drill-in-bucket method, with sock-and-kneeding method, even now-- WEEKS of trying. However an individual plastic sleeve of CYA bought the same time dissolved almost instantly -- did we just get bad CYA in the canister?
3. A bunch of "Clorox Oxi Chlorine Free Shock Oxidizer" was added recently to try to keep pool from swampifying while until we could pay attention. Probably 5-6 lbs. Is it maybe giving me fake chlorine readings? No Chlorine has EVER been added due to cya never getting up to snuff -- we figured chlorine would just get destroyed by UV anyways, then pool got ignored. Should we add chlorine now or start with new cya in the sleeves first?
4. It is also pollen dump season and the pump was left off for a week and the pool became golden soup -- it has been running for 48 hours now with filter basket sock changes during the day and no sock at night. And backwashed 3 times to clear up pollen. And we've been cycling the pool robot (Dolphins100) throughout the day. Any other tips?
5. Pool math says to add borax -- based on everything else should i really do that now or sort out other stuff first?
What should i do first? Thanks very much!
