If you must use trichlor tabs look for plain 99% trichlor - avoid anything with the word blu/blue in it.
As mentioned above you must watch your cya to be sure you’re following the correct
FC/CYA Levels
and trichlor is also acidic so take that into consideration
Use
PoolMath effects of adding to see how each tab will affect your parameters. Most 3” tabs are 8oz. Jumbos usually 10oz.
Use a floater and don’t allow it to just rest in one area.
If using cal hypo tabs this will increase your calcium.
Use poolmath to see the effects.
*Trichlor and cal hypo tabs cannot be used interchangeably in the same floater/dispenser.
They must each have their own dedicated floater/dispenser for life or an explosion can occur if even traces are mixed.
Your pool isn’t very large so it may be more practical to just use unadulterated household bleach/ sodium hypochlorite.
Just be sure it has : No scents, no fabric conditioners, no cloromax technology, no splashless.
Plain is generally found with store brands- at places like walmart, aldi, dollar general.
Plain Chloralen brand is also good choice and is 7.5% strength. Its on sale for $2.79 a gallon at Walgreens right now. I will be picking some up for my hot tub today.
Just as with all liquid chlorine/sodium hypochlorite you want to check the date code and buy fresh stuff.
