Hello, a couple of months ago I had an algae bloom infiltrate my pool. I made the mistake of failing to clean my filter AND shock the pool properly. I just kept adding tabs and the algae problem persisted. I finally wised up and cleaned out my filter cartridges, but the weeks I spent adding pucks caused my CYA to spike to 180. I drained the pool (almost entirely), added stabilizer to return my CYA to its optimal target level of about 50, and SLAM'd using liquid chlorine. As of today the pool is crystal clear and back in balance.
I have stopped using tabs and solely use liquid chlorine from Home Depot. My question is around the relationship between FC and pH. My CYA is about 50 or so, and according to the Chlorine/CYA Chart my Target FC is 5.7. As of Monday the 29th my FC was a little low (at 4) but my pH was perfect (at 7.5/7.6). I added chlorine that morning and as of today the chlorine is 5.5 but my pH is back up to 7.8. I feel like I am constantly going back and forth between slightly lower than target FC but perfect pH, and target FC but high pH.
Any thoughts or suggestions? I use a Taylor K-2006 test kit, fyi.
