If I need to add liquid bleach to raise chlorine levels, but also need to add muriatic acid to lower my TA, do I need to add one before the other, or can the chemicals be added at the same time?
It doesn't really make any difference in the order.. technically adding chlorine will affect the PH and salt content a little. I usually do Cl first if its enough where I think it will affect my pH significantly.
