s_vidden
0
demilio56,
Just want to double check that you are aware that FC does not deplete linearly. Extreme amounts of FC will deplete much quicker than FC several points above your target. It is not a X amount of ppm loss per hour. With CYA of 50 and FC above 44, you will experience exponential loss in FC compared to FC just below the recommend shock level.
You also mentioned your not entirely confident in your last CYA test. Have you tested recently? I like to test 3 times in one session if I am unsure of my findings and take the average. Just dump the solution back into the droplet container and retest again. Also, visit the Pool School page if you are not sure how to accurate test CYA. I place my back towards the sun around 10-11am on weekends and hold the test vial at waste height and proceed.
